0 Members and 1 Guest are viewing this topic. Read 3615 times.
Does it skip inward or outward?Wayner
How do you know that anti skating is set correctly? A skipping tendency which is always to the outside edge of the record indicated too much anti-skating force - at least at that part of the arc described by the arm; it varies across the arc even with the best designed systems (and there are many different systems for applying anti-skate force).By the way, if it repeats the same spot over and over I would describe that as skipping outwards - to the outside edge of the disc.
If there is too little anti skating, skips will tend to be towards the center of the record. If there is too much, skips will be towards the outer edge.I believe on some of the old set up vinyl discs there is a blank section with no groove for setting up anti skating. The idea is you adjust for no arm movement in or out.
