0 Members and 1 Guest are viewing this topic. Read 8625 times.
The mac mini s is known to be the best transport computer period! I know several people who use them and swear by them. Hint: Do not use itunes!
Mac Mini and the Macbook/Macbook Pros use roughly the same hardware. The one advantage macbooks might have over the mac mini is the ability to run it from the battery if you feel the wall wart is a bit noisy. I think the main reason why the mac mini is so popular is the price. Macbooks/pros also have a few advantages as you aren't required to have an external display where your stereo is at.
There's no need for a display. I use the built-in desktop sharing to control my mini over the network from any of my other machines. As for noise from the power supply, using the toslink connection should pretty much cut noise out of the equation.
Mac Minis rock for a music server, but my point was any macbook would have the same features as they pretty much have identical hardware. Both will work equally as good and per each users requirement you can find a role for each one. If you are the type that like to have a battery only gear then a macbook would also help you fill that role and you still can use the toslink for additional noise separation.Even more comforting if you go to Benchmark's wiki you can see their test results proving that iTunes and Macs can be bit transparent.. So that's even one more win for the mac hardware.
Thanks for your recommendation Lizard_King. After long search for external drives for my Mac Mini, I have ordered two of the 1 TB Mini Pro Firewire 800/USB drive. It appears just what I have been looking for...no flashy lights, minimal noise, well-made aluminum case, good Firewire/USB chip, and compact size. A little more expensive than other external drives I have looked into, but Oyen has a 30 day return policy if things don't work out.
My MAcbook server is SSD internal and is wonderful. Quick boot ups, silent and no issues. Great for the OS and apps; too small for music.
I got a 128bg Kingston SSDnow gen 2 SSD drive
