Buffalo 32 PS & Transformer - What Else?
0 Members and 1 Guest are viewing this topic. Read 1074 times.
jkelly
« on: 23 May 2010, 01:51 am »
Got my order in for the Buffalo32 and PS.
Besides the case and connectors - do I need anything else?
Thanks.
Jeff
mgalusha
Re: Buffalo 32 PS & Transformer - What Else?
« Reply #1 on: 24 May 2010, 02:59 am »
If this is for the new Buffalo then you need some type of output circuit. Lots of options, discrete solid state, op-amp based, tubes, transformers. All can sound good, depends on what you like. :)
I've built one with tubes and another with transformers, both sound excellent, just a little different. It's important to chose or design something with low noise since the ES9018 has stellar noise and distortion specs.
mike
