Bryston aesthetics
0 Members and 1 Guest are viewing this topic. Read 1595 times.
Napalm
Bryston aesthetics
« on: 22 May 2010, 05:49 pm »
This is mostly for James.... I was staring at the 4B while listening Chopin this rainy morning....
I wonder if it would be possible to have the power switch made from a piece of brushed aluminum with "SST2" engraved by CNC mill too.... similar to the front panel....
I vote for just "SST2" as the same part could be used in all amps....
My taste says that at least in black it would be GORGEOUS.  :drool:
Nap.  :thumb:
werd
Re: Bryston aesthetics
« Reply #1 on: 22 May 2010, 06:03 pm »
Napozer
You told us you don't like listening to your 4B, we thought you only listened to your $300 future shop stereo.
You say it sounds better.
 :rotflmao: :jester:
Napalm
« Reply #2 on: 22 May 2010, 06:07 pm »
Napozer
:rotflmao: :jester:
Define better  :eyebrows: I said pleasant and easy to listen to.
Nap.  :thumb:
werd
« Reply #3 on: 22 May 2010, 06:23 pm »
Nap.  :thumb:
Ok, you said more pleasant and easier to listen to than your system with the 4B and the paradigms....
Napalm
« Reply #4 on: 22 May 2010, 06:28 pm »
Yes, I have some reflections in the 4B room that I can pretend to ignore for a while but it becomes fatiguing during long listening session.... There are new curtains and some furniture on order so this might change....
Nap.  :thumb:
