Borrowed Technics has lost a channel
0 Members and 1 Guest are viewing this topic. Read 1442 times.
S Clark
« on: 20 May 2010, 12:50 pm »
A friend has loaned me his incredibly massive Technics vinyl rig, and I have enjoyed it for several months.  However a couple of weeks ago, it suddenly lost its right channel.  Is the most likely candidate the tone arm wire? If so, how complex a project is replacing it?  What wire should I use?  This are no model numbers on it, but it is perhaps 75 lbs, and  has a seperate power supply. It appears to be at least 15 years old.
update: It's an SP-10
jsaliga
  • Vinyl Provocateur
    • The Spinning Record
Re: Borrowed Technics has lost a channel
« Reply #1 on: 20 May 2010, 04:54 pm »
It could be a problem with the tonearm wire, or even the headshell leads.  The latter isn't too costly and difficult to replace.  Replacing tonearm wire is more involved and expensive.
I don't know if this thread on Vinyl Asylum applies to your model, but judging from the pictures it is a fairly complex piece of work if you haven't done it before.
http://www.audioasylum.com/audio/vinyl/messages/75/755529.html
--Jerome
Wayner
« Reply #2 on: 20 May 2010, 05:11 pm »
Cartridges fail to. Swap left and right channels on your cartridge and see if the dead channel changes.
Wayner
jsaliga
  • Vinyl Provocateur
« Reply #3 on: 20 May 2010, 07:34 pm »
Excellent suggestion, Wayner.
--Jerome
Wayner
« Reply #4 on: 20 May 2010, 08:12 pm »
Thanks Jerome, but I only speak from experience, not knowledge, as I just had one die because the coil wire circuit became open. I mean the wire is so fricken small, that it may only take a static discharge to fry it, or it can come loose from the pins. This wire is way smaller then a human hair. Perhaps this is another good reason why TTs are grounded, to take the static charge away.
Wayner  :D
