EI Transformer radiation pattern
0 Members and 1 Guest are viewing this topic. Read 992 times.
sts9fan
« on: 19 May 2010, 02:32 pm »
I am finally putting together my Akidio pre and I have a few questions about transformer placement.  I am doing this as a vertical build and would like to put the transformers in the bottom with the PS on top of them and the signal stuff above that.  Do you think I would be ok?  The amp circuit will be ~10" above the transformers.  I know little radiates from the laminations but is this ok?  The bells will be facing the sides. Opinions?
Kris
