0 Members and 1 Guest are viewing this topic. Read 10933 times.
You might be able to use a square wave signal at certain frequencies and levels. Then, you'd test using an oscilloscope without the current limiting device in place to get a baseline. (You'd compare input signal versus output signal.) You'd then test with the current limiting device and see what differences (in output signals), if any, exist. You always have to be concerned with the limitations of the testing equipment. You also have to determine how realistic this is for music reproduction.I don't think you could use a wideband signal, as that wouldn't tell you anything and is a steady state response.
jtwrace - With an oscilloscope ofcourse!!!
nobody?
Dave, I think that the current limiting is determined by the interaction of the source impedance of the AC power line (including the devices and wiring between the wall outlet) and the input impedance of the amplifiers power supply. Now some power amplifiers AC input draws huge current spikes for a fraction of each AC line cycle (these spikes may be 3 or 4 times the continuous current! that's right 50 to 80 Amp spikes). Now I don't know how a high source impedance affects the performance of this type of amplifier, so that's the first thing that should be tested. Nor do I know how a (non MOV) surge suppressor (one that uses an inductor) reacts to high current spikes, so that the second thing to be tested.I don't see how an IEC unit has much impact on the source impedance nor do I see any meaningful difference between a 13A and a 20A unit.
Dunno Dave, but for the hellame, just can't see a 6x contact area....maybe 2X . But I wear glasses, and everything looks slightly smaller through it.
Jason, The easiest way to determine current limiting in a particular device is to determine the series resistance, the inductance of the unit, the capacitance of the unit, the AWG of the conductors and the contact area and pressure of the attendant (clean) connectors. A well designed power filter should have its' ultimte current handling and current limiting determined by the I/O connections.
In the case of any of my units, R = < .003 ohms , L= < .003 mH and C= < 200pf in the EMI/RFI core which is the only series component. The conductors are ~ 10AWG. Given this, the current handling/limiting is determined by the input IEC (which is why I prefer the 20A IEC units) and the output receptacle. The Pass & Seymour that I use a lot is a 5362 Spec Grade unit with .036 contact fingers rated in excess of 20 amps. C= 9pf R=< .001 ohm L= < .001mH. All of my I/O connectors meet or exceed these specifications. In other words, although they limit current purely by the fact that they have an LCR component, I defy anyone to accurately and repeatably measure the actual loss without 5 digit meters. It can be computed, of course (< .01 A). A dirty or oxidized plug will show more current limiting than any well designed filtration device with low inductance and low series resistance. If you want to get all of this loss back, simply polish the blades on the plug. ...
...I just took the myth out of power filtering for all of you....This is the proper way of doing power filtering for audio and this is the BEST way. Period. ..Thread closed.
