Reading Fuses
0 Members and 1 Guest are viewing this topic. Read 2897 times.
Eric
Reading Fuses
« on: 17 May 2010, 08:37 pm »
How do you decipher the value of fuses. Soe of them in my gear have letters like D or F followed by a number then the letter A. Do the letters D and F have values?
Wayner
Re: Reading Fuses
« Reply #1 on: 17 May 2010, 09:12 pm »
As an example a fuse labeled ABC-10 250VAC, the ABC is a fuse style, the 10 is the amperage rating of the fuse and 250VAC is the voltage rating. All fuses also have a designated fail type like "slo-blo".
The real message here is to always replace the blown fuse with the same type and rating. If the fuse blows quickly again, it's time to see the doctor.
Wayner  :D
Eric
Re: Reading Fuses
« Reply #2 on: 17 May 2010, 09:14 pm »
How do you tell if it is a fast-blo vs slo-blo
Wayner
Re: Reading Fuses
« Reply #3 on: 17 May 2010, 09:28 pm »
Usually slow blow will say on the fuse cartridge. Look on the metal cap. If it doesn't say slow blow, it isn't.
Wayner
Eric
Re: Reading Fuses
« Reply #4 on: 17 May 2010, 09:44 pm »
The reason I am asking is I am looking to go to some high perfromance fuses. The 5x 20's are hard to read.
*Scotty*
Re: Reading Fuses
« Reply #5 on: 17 May 2010, 09:51 pm »
Owner's manual?
Scotty
Wayner
Re: Reading Fuses
« Reply #6 on: 17 May 2010, 11:16 pm »
There is no such thing as a "high performance fuse" IMO. Ask the guy you got them from. You can also ask him if they are UL listed.
Wayner
Wayner
Re: Reading Fuses
« Reply #7 on: 17 May 2010, 11:20 pm »
I'm so sick of claims by snake oil makers about high performance shit, just like this. Perhaps you should have loaded your quandary at the beginning.
W
