Tube Rolling-Tips please!
0 Members and 1 Guest are viewing this topic. Read 1449 times.
eclein
« on: 14 May 2010, 09:14 pm »
Hi guys, I got a Grant Fidelity Tube DAC-09 on its way to me and some tubes from a fellow AC'er...When I roll tubes how long should I give unit with swapped tube before I start seriously listening?? Do I give it an hour then be able to evaluate the tubes effect properly. I'm totally new to tubes...got a (NIB) GE 5670WA, a Western Electric 396A and whatever it comes with...Thanks :thumb: :thumb:
SteveFord
Re: Tube Rolling-Tips please!
« Reply #1 on: 14 May 2010, 09:20 pm »
Brandy new tubes can take quite some time - 50 to 100 hours in my stuff.  I don't know about that particular piece, though.  YMMV as they say.
eclein
« Reply #2 on: 14 May 2010, 09:38 pm »
Thanks Steve, I had no idea break in time was so long, I figured an hour and boom its how its gonna sound. Thanks-I'll let the tube it comes with burn in for a week or so then start swapping...
 Ed L.
troutboy
« Reply #3 on: 27 Jun 2010, 11:00 am »
Not sure if the DAC tube will react similarly to the ones in preamps and amps, but usually you can start to tell if you are gonna like it or not within an hour or so.  You can roll through tubes and cull the ones that absolutely don't work with your system, then give extended listening time to the ones you like the best.  Usually takes several elimination rounds to single out the ones that work with the system, but usually you can tell pretty quickly if the tube has a sound that you like or not.
Brand new tubes are a different story.  Seems like they change for the first few hours or so then settle out.  I have tried some that i didn't care for at first, but after a little time on them they came around.  So don't write a new tube off based on first impressions.  Put it in the system some weekend when you can just let the system play and give it some time and then see if it changes tone.  Have fun with your rolling.
Mike
Knoxville, TN
