FS: Kenwood KM-X1 Amp. $199
0 Members and 1 Guest are viewing this topic. Read 11428 times.
berchman
« on: 14 May 2010, 07:57 pm »
Works perfectly, very good to excellent cosmetic appearance. Vicinity of Harrisburg, PA. User manual available from:
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/kmx1.pdf
•   6 Channel, THX certified, 100 Watts RMS per channel,
•   6 RCA inputs, 6 light indicator on front brushed aluminum panel,
•   built like a tank!!! Banana plug hookups in rear,
•   VERY Nice Amp - is VERY Heavy, ships at about 60 lbs.
•   10Hz - 100kHz, .0015% thd
When it was introduced the KC-X1/KM-X1 amp/preamp combination was Kenwood's flagship THX system. The KM-X1 6-channel amplifier is capable of 100W rms per channel or 130W per channel in stereo mode. The KC-X1 preamp has several DSP modes for Dolby Pro Logic, stereo and THX Cinema. As well as the usual array of audio inputs it has several VCR input/ouput connections and has on-screen menus. It also has an FM/AM tuner.
To quote from one owner’s online review: “. It (Kenwood KM-X1 power amplifier) has 6 channels and is a ridiculously powerful and excellent sounding bit of gear. It looks like a black steel behemoth. Combined with its original separate and very hard to find KC-X1 Pre amplifier it is a trip into Japanese Audiophile territory on a budget. The sound quality is better than any HT or power amp I’ve heard for under 2 grand, and believe me I’ve looked hard for a long time to find an amp powerful enough to get my original factory built in California 15" JBL TPC (concert quality) subwoofers moving. In fact this amplifier not only moves the subwoofers into ridiculous levels of bass, it also still has enough current to allow the midrange driver and tweeter to still sound perfectly clear. There can be no comparison between this and new home theatre packages. The KM-X1 is on a completely different level.”
Also for sale: $99 Kenwood KC-X1 THX digital av control amplifier/tuner.
This preamp processor decodes THX,dolby pro-logic,dolby 3 stereo,mono,and dsp logic in the digital domain.The Kenwood turns all analog inputs into digital signals for decoding and then turns them back into regular analog signals at the outputs which you then connect to outboard amps you own.There are no digital inputs or outputs just regular analog inputs and outputs.
Serves as a preamp and tuner providing inputs for turntable, cd player ,two tape decks, 4 video inputs with rca or two with s-video and three monitor outputs with 2-rca and one s-video. There are 3 a/c plugs on the back and a pre out THX 25 pin plug for connecting THX amps. Has built in THX 80hz crossover on/off switch on the subwoofer output. Also has remote output jack for connecting other Kenwood amps. Includes am/fm tuner. Comes with learning remote control and 25 pin plug.
This preamp/tuner can be bought separately for $99 or together with the amp for $275. User manual can be downloaded at
http://inform3.kenwoodusa.com/manuals/kc-x1.pdf
