Piccolo - Decals / Silk Screening
0 Members and 1 Guest are viewing this topic. Read 1915 times.
bluenoteJML
« on: 12 May 2010, 11:19 pm »
Hi - open question for all.  What are you doing to get the decal onto the enclosure for the piccolo HA?  Thanks.
harryf
Re: Piccolo - Decals / Silk Screening
« Reply #1 on: 12 May 2010, 11:50 pm »
There are decal sheet's you can use with a laser printer.The only place i have seen them is online but i know modeler's use them to make custom decals.I have not used them yet.
Allen
« Reply #2 on: 13 May 2010, 03:20 pm »
I've set up a document in Front Panel Designer, a 4mm black anodised plate with the engraving left silver comes out at 46€. Hopefully this is reasonably accurate, I would urge anyone to check it before ordering a panel.
You can download the file from:
http://www.sendspace.com/file/b3ef2t
The software is from:
http://www.schaeffer-ag.de
in Europe
http://www.frontpanelexpress.com
in the USA
« Last Edit: 17 May 2010, 11:40 am by Allen »
ecir38
« Reply #3 on: 14 May 2010, 04:30 am »
Nice job thanks for sharing. This is a newer version of front panel, looks to be allot better have to get familiar with it.
Brad
Allen
« Reply #4 on: 14 May 2010, 10:07 pm »
I've used it for a few things now, at long last there's a Mac version, I used to have to borrow a pc - it's really easy to use and the panels are very nice quality.
Not sure if I can afford to do this for my Piccolo though. Shame because it would look great.
bluenoteJML
« Reply #5 on: 15 May 2010, 01:31 am »
Thanks all for the replies.  I really like the front panel design.  Much appreciated.
Allen
« Reply #6 on: 17 May 2010, 11:41 am »
bluenoteJML
« Reply #7 on: 11 Jun 2010, 01:31 am »
Hi - Just thought I'd add that I ordered the latest tweaked front panel file that Allen posted.  Beautiful and fits pertfectly.  I'll post pictures when the build is complete.
