0 Members and 1 Guest are viewing this topic. Read 30550 times.
How about this Gainclonehttp://www.hllyelectronics.com/html/fm_transmitter_1_174.html
Has anyone tried this amp?http://www.tnt-audio.com/ampli/scythe_sda1000_e.htmlI'd never even heard of it until I saw a picture in the AC homepage gallery.
http://www.diyaudio.com/forums/vendors-bazaar/147589-hlly-tamp-90-ta2022-chip-true-pearl.html
The HLLY TAMP-90 still hasn't broken in yet and its sound is changing a lot. So far its very warm, lots of rich bass. NOT bright, somewhat rolled off on the top end and the mid-range is a row back. Enough detail, nice deep sound stage – good imaging. A little reserved, definitely a trade off between richness and transparency (didn't expect it to do it all did you?) For its price – WOW but how does it compare to my McAlister SET? It doesn't really, the McAlister is better in all ways but still the HLLY is excellent; my McAlister is a bargain at $2000+ and this HLLY is a steal at $200!! Using my Preamp made a significant difference. But I expected that, without the preamp its still nice but the preamp adds lots of musicality (also a McAlister). I started power-cord rolling but its still too soon. Tried a Harmonic Tech Fantasy Model-10 which is an amazing PC but may be too rich/warm for this amp. I have others to try. Time will tell.
I would imagine that if you were at all up to it, huge gains would be made in transparency (or whatever tone suits you) by putting in new output caps, as those are typically a major bottleneck/determinant of sound quality for T-amps and are usually so-so quality stock.EDIT: Looking at the pic at the top, looks like they use some kind of cheap Epcos caps (so-so), and I see extra holes to accomodate larger size caps, so they clearly anticipate people switching them out. I highly, highly recommend you give that a shot if you can...
