Anthem D2 Statement 7.2 with 4 HDMI
0 Members and 1 Guest are viewing this topic. Read 1355 times.
frostbyte3964
« on: 12 May 2010, 02:44 pm »
I'm selling my Anthem D2 in original box with 2 remotes and Manual (digital copy).  It has 4 HDMI inputs, set up for 7 channel operation with possibly 2 subs and possibly 2 center channels. Amazing unit. No issues that I know of, although I don't use but 2 inputs so I haven't tested everything out. I use it with my iTouch and my Blu ray player. Tuner works fine also. It's a beautiful piece as well. You can add the ARC if desired by contacting Anthem. I had no need for it with my set up as I used a DEQX instead. Ships from 84074. Selling for $2900 or best offer.
« Last Edit: 12 May 2010, 04:06 pm by frostbyte3964 »
Bill@LakeGeorge
Re: Anthem D2 Statement 7.2 with 4 HDMI 1.3
« Reply #1 on: 12 May 2010, 03:35 pm »
I'm selling my Anthem D2 in original box with 2 remotes and Manual (digital copy).  It has 4 HDMI outputs, set up for 7 channel operation with possibly 2 subs and possibly 2 center channels. Amazing unit. No issues that I know of, although I don't use but 2 inputs so I haven't tested everything out. I use it with my iTouch and my Blu ray player. Tuner works fine also. It's a beautiful piece as well. You can add the ARC if desired by contacting Anthem. I had no need for it with my set up as I used a DEQX instead. Ships from 84074. Selling for $2900 or best offer.
This is a great unit at a good price but it should be noted that it has 4 hdmi inputs and only one hdmi output.  I also believe it is only HDMI 1.2 compatable
frostbyte3964
« Reply #2 on: 12 May 2010, 04:07 pm »
Oops. Not sure the difference in 1.2. and 1.3. Definitely not 4 outputs. My bad. Good catch
