WD My Passport Essential 640GB
0 Members and 1 Guest are viewing this topic. Read 1609 times.
jqp
« on: 12 May 2010, 01:21 am »
WD My Passport Essential 640GB for $92 at Best Buy - you will pay $119 at Newegg...
This beauty is as small as your cell phone and is usb powered.
The same drive with 500GB capacity is $109 at Best Buy!
There may only be 1 or 2 left _ I got the last one at my downtown Best Buy
« Last Edit: 12 May 2010, 03:24 am by jqp »
  • Speakers....What Speakers ?
Re: WD My Passport Essential 640GB
« Reply #1 on: 12 May 2010, 02:55 am »
Something I have read about this.... :?
Beware of WD's SmartWare software.....
"BUYER BEWARE....This is a great hard drive, except for one fatal issue. Western Digital includes their backup software, "SmartWare" on this drive. That's normally not an issue, you reformat and partition the drive and it's gone. However, WD included a special virtual CD (VCD) partition as part of the enclosure or firmware, which is NOT accessible to the user. I've tried all the utilities in OS X, Windows, and Ubuntu Linux to destroy this VCD, but no luck. I contacted Western Digital inquiring about a removal utility or firmware flash, and they gave me a run around answer and basically said no, we have no plans to do that. The VCD automatically mounts on your machine when the drive is inserted, which gets annoying very quickly. I found a workaround in OS X and Windows, to keep the VCD partition from mounting, but it shouldn't have to be this way. If you've ever had to deal with the horrid U3 software on a SanDisk flash drive, then you'll know what I'm talking about. At least SanDisk provides a utility to remove their software, and gain back the full capacity of the drive. This SmartWare VCD uses almost 1GB of the drive. A drop in the bucket, yes, but I don't like being told how to use my storage space by Western Digital. Aside from that, it functions and is built quite well. My only other complaint is that the barrel plug for the power adapter, and the USB cable sit pretty loosely in the back of the drive when they're connected and are prone to falling out if you move the drive around too much. Otherwise, a good hard drive."
See other comments here....Link...
jqp
« Reply #2 on: 12 May 2010, 02:59 am »
Yeah I just reformat - guess I will repartition too, thanks
Also the included usb cable is a VERY tight fit so it won't be falling out by mistake :)
skunark
skunark
« Reply #4 on: 12 May 2010, 03:08 am »
lol, that is a crappy link, but if you go to the WD website and search for remove smartware. then you will eventually find it..
jqp
« Reply #5 on: 12 May 2010, 03:26 am »
Here is the link
http://www.wdc.com/wdproducts/updates/?family=wdsmartwareutilities
So I wouldn't buy it for my mother before setting up for her, but nice of WD to at least provide a clear method to remove the VCD.
The whole thing took me 10 minutes from downloading the 2 utilities to removing the VCD - no more virtual CD appearing :}
Then I deleted the partition and created a new Simple Volume and now doing a complete format. Thanks Chris for pointing this out.
