NOS GZ32 for the clarinet
0 Members and 1 Guest are viewing this topic. Read 1317 times.
ixe13
« on: 11 May 2010, 09:22 pm »
Hi,
I have 2 Gz32 doing nothing in their boxes. One Brimar and one Ultron.
I just noticed that The Sovtek 5Y3GT in my Clarinet started to be noisy. When I gently shake it, I hear "Clink"  "Clink" inside... Not Good...
So, I'm wondering if I could put one of these GZ32 to good use in the clarinet.
I checked the spec and they look similar enough to the 5Y3GT but I tought to ask just to make sure.
Thank in advance for any advices or warning.
Yves
poty
Re: NOS GZ32 for the clarinet
« Reply #1 on: 12 May 2010, 11:22 am »
I think you can use the GZ32 insead of 5Y3GT. The only "question" - the rated anode voltage, but it is greater than in the Clarinet, so - no problem.
ixe13
« Reply #2 on: 13 May 2010, 01:05 pm »
Thanks Poty,
Also, I've notice that these 2 tubes has the "coke Bottle" shape, so it bring the tube glass closer to the transfo, heating it up, will have to keep an eye on that...
Again, thanks
Yves
ixe13
« Reply #3 on: 25 May 2010, 01:05 pm »
Just a little update on the GZ32,
After a few days of using the clarinet, This coke bottle doesn't seem to heat up the transfo that much cause it's barely warm just as before.
I dont use the system for more than 1 hour to 2 at the time, but no sweat (no pun intended, or maybe a little)
And I didn't notice any change soundwise,
So all is well
Yves
