0 Members and 1 Guest are viewing this topic. Read 8068 times.
The Cokes, chips and beers are on me.
OzarkTom brought his Piano, Sensation, Gallo Stradas and a little subwoofer... and no room treatment at all... the setup sounds UNREAL. Wow, my god, I'm still a bit choked up. Tom was a hifi dealer for 15 years and has seen a thing or two. He's a true believer and you know, his room is that good.
The unit does very strange things if you don't shut it down properly before changing power supplies. Give it 90 seconds rest for the caps to all fully discharge and clear the computer memory, and it comes back fine.
Gary also brought a bunch of these battery supplies. I gave OzarkTom one and the last bit of harshness in his system is GONE, GONE, GONE. As Vinnie has known for a long time, batteries really matter.
James T. You are here with us in spirit. Your Sensation M451 with the Mundorf caps is every good as you said it was. Thanks for sending it out!!!
