0 Members and 1 Guest are viewing this topic. Read 10251 times.
Hey all,He started with the left speaker and pulled it back about 3". WHAM!!! All of a sudden, I had a HUGE soundstage with depth (in all of my listening sessions before with the speakers being at equal lengths from the back wall I never really had much soundstage depth) and the imaging was very very precise. As soon as he moved the right speaker back the same 3" to match the left, the soundstage and imaging was back to what it was before.Why would this be? Is there something about my room that would lend itself to this particular setup? Needless to say, if it's what it takes to get into the magical sweet spot for listening I'll live with it, but it just seems odd that in order to create that magic spot the right speaker has to be about 3" inches further out than the left. Anyone else ever experience this?
Well, hopefully nobody will jump all over me for posting this in response to the above observation. But, have you ever heard of Master Set?You've got a room situation where the right speaker has a lot more boundary reinforcement and will project a lot more sound pressure into the room space. The left speaker has a far larger space to pressurize, with the open room space, and the only way that it can compensate for this is to be closer to the wall behind the speaker. This will somewhat equalize the amount of sound each speaker will put into the room.If you like the sound with the 3 inch offset, well, go with it. Most folks wrongly believe that speakers should be equadistant out into the room from the wall behind them. This is not so, as you've just found out. Trust your ears, not your tape measure.
Thanks for the continued responses guys.stvnharr - In scanning through this circle, I've seen mentions of the master set, but really have not tried it yet. Possibly on my next "home alone" session Your explanation of why the 3" forward on the right speaker sounding better makes sense. Just looked kinda funny seeing one speaker out further from the other when viewing the setup from the side. The sound was absolutely fantastic though so I'd feel kinda silly not trying it again.
A lot of speaker designers have gone to great lengths to preserve and deliver what's in a recording.
Hmmm guess what I'm learning from all this is that I need to play around with speaker positioning a bit more. The goal is to find the spot that works best and write it down so it can be repeated quickly for those times where I can listen without interruption.
He started with the left speaker and pulled it back about 3". WHAM!!! All of a sudden, I had a HUGE soundstage with depth....Why would this be?
I believe this particular issue is likely more related to the reflections from the side wall. Bryan
