Crossover design load
0 Members and 1 Guest are viewing this topic. Read 1428 times.
chlorofille
  • 8'' MTM with scanspeak 21w8554 & D2904 7100
« on: 7 May 2010, 09:47 pm »
Hi guys,
A passive crossover can be designed for a variety of speaker loads: (4/8 Ohm)
If I have 2 identical 8 Ohm mid-bass speakers wired in parallel and would like to design a crossover, should it be based on a 4 or 8 ohm speaker ?
I have been cracking my head for ages and still cant find an answer.
« Last Edit: 8 May 2010, 07:07 pm by chlorofille »
Davey
Re: Crossover design load
« Reply #1 on: 10 May 2010, 01:46 pm »
Normally, you would design a crossover for a measured (across the full audio band) speaker impedance vice using the nominal rating of a particular driver.  However, if using a generic calculator and using nominal impedance ratings you would use 4 ohms for your example.
Dave.
chlorofille
« Reply #2 on: 10 May 2010, 03:42 pm »
Thanks Davey. Am planning on using 2 scanspeak Discovery 8 inch, 8 Ohm woofers in parallel crossed over at 300Hz LR2 to a 4inch midrange.The woofers have exceptionally smooth impedance from 100 to 700Hz of based on SS's graphs. Also this would allow me to use smaller crossover component values as the load is 4Ohms.
Chloro
« Reply #3 on: 10 May 2010, 04:33 pm »
IF you connected two 8 ohms drivers in parallel the xover will see it as one driver and 4 ohms impedance, then a suited xover can be done.
There is a site offering xover desing, and desing + building xover services, the prices are low >>  http://www.audesine.com/cd.html
Cheers,  Gustavo
