Omega Mikro Red and Blue 900-Watt and 100-Watt power cords
0 Members and 2 Guests are viewing this topic. Read 803 times.
mikeg1
Omega Mikro Blue and Red 900-Watt and 100-Watt power cords for sale. Original owner and about one year old. I went from separates to integrated and eliminated the subwoofer in my sysyem and no longer need these cords. This cord replaced the Wireworld Gold Electra 5 squared (a little more transparent for half the price).  $425 plus shipping for each cable. These are $1003 each retail. I have one of each: red 900w, red 100w, blue 900w and blue 100w.  Pls check my agon feedback under mikeg.
From the OM website:
900-Watt Active
The 900-Watt Active power sounds best five feet long. If you can?t make a five-foot power cord work in your installation longer lengths are available as custom orders.
The 900-watt rating is conservative and represents the limit on continuous average power. Short peak demands, of the duration of loud musical peaks, up to 3000 watts can be safely handled.
The 900-Watt power cord uses pure copper ribbons with optimized geometry and processing protocols to transfer power between the source of power and your components. Each ribbon is insulated using the same multi-polymer film used in our interconnects. We designed our AC plug to sound better than anything else we could find, including hospital-grade plugs and other such devices that use unnecessarily large amounts of bad sounding dielectrics.
Our silver-plated fine copper braid on the outside shields and protects without adding more dielectric. Our IEC socket uses minimal dielectric and compression connections instead of solder. The compression fittings float in their compartments so that they?re loosely coupled to the polymer dielectric and are mostly surrounded by air.
This combination of features assures that our power cords achieve the same high standards of time domain fidelity as our interconnects. Our 100-Watt Active Power Cord will make your low power components sound better than you?ve ever heard them. The 900W version is best suited for higher power applications like amplifiers with the same attributes as the 100W.
Our active power cords are identical to their passive counterparts except they use a 9-volt bias voltage from a battery and network supply box. The bias applied to the shield further reduces the residual smearing effects from our already minimal multi-polymer dielectric. With the reduction of smearing, the impact on the sound is immediately obvious; micro dynamics and transients are reproduced with greater clarity, backgrounds become blacker and more solid. Leading and trailing edges are more like live and have an excitement and presence you must hear to believe.
The battery/network box is finely crafted from bird?s eye or curly maple, which further contributes to clean sound and looks great too.
« Last Edit: 13 May 2010, 06:57 pm by mikeg1 »
mikeg1
friendly bump
