Headphones and Bryston Amps
0 Members and 1 Guest are viewing this topic. Read 1768 times.
Moon Doggy
« on: 1 May 2010, 01:38 pm »
The manual for my new B100 Integrated Amp says that "only headphones with impedances of greater than 50 ohms should be used."
What will happen if I use a pair of phones @ 32 ohms? Will it just affect the sound?  Could there be damage to the headphones or amp?
Just wondering.... :dunno:
Napalm
Re: Headphones and Bryston Amps
« Reply #1 on: 1 May 2010, 03:26 pm »
Get a pair of these:
http://www.akg.com/site/press_center/powerslave,id,163,nodeid,0,_language,EN,nodeid,33.html
and you'll never look back. Right impedance too.
Nap.  :thumb:
rob80b
« Reply #2 on: 1 May 2010, 07:50 pm »
Hi Moon  Doggy
I was into headphones in a big way when my son was younger, I still keep them on hand and went trough trial and error trying to get the best performance out of them. The Bryston headphone output will drive most headphones satisfactorily but it’s running off the preamp output, no nothing will happen to the phones or the Bryston.
My biggest problem with the Brystons was that to drive most of my phones, AKG 501s, AKG701s, Sennheiser HD580/600s the volume needs to turned up fairly high, 2-3 o’clock (ok I like to listen loud) and is actual too low when listening to vinyl. Not only that but on occasion the phones were disconnected while the things were turned up sending the full output to the amp/speakers.
Also, my Grado SR325is at 32ohms, will run on a pea sized amp and have more than enough volume with the Bryston but they like current to sound their best which is why 50 ohms and above is mentioned.
So to answer your questions, you should have no problems whatever running 32 ohm headphones, they’ll just be current hungry, just try them and see if it’s adequate.
Which phones are you planning on using?
Robert
Moon Doggy
« Reply #3 on: 1 May 2010, 08:07 pm »
Robert
I don't have a pair of phones yet but I was thinking of the AKG 701s or the beyerdynamic DT990 @ 250 ohm.
Good to know that if I borrow my friend's Grados it won't be a problem.
Thanks. :)
rob80b
« Reply #4 on: 1 May 2010, 08:16 pm »
Both are great headphones although I prefer the AKG701s. Not that there is anything wrong with the Bryton but for reasons stated above I'm running mine off a Shanling PH1000, a great bargain IMHO, which has more than enough current and volume to power the hungry 701s or any headphone.
Robert
Napalm
« Reply #5 on: 1 May 2010, 09:27 pm »
My vote for AKG.
Nap.  :thumb:
mkaiser
« Reply #6 on: 2 May 2010, 04:15 am »
Just wondering....
Do yourself a favour and spring for a dedicated headphone amp. No stereo preamp or integrated amp will come close to the performance and proper impedence matching to properly drive a set of cans.
If you can afford it check out these headphone manufacturers for their amps and various popular headphones.
http://www.gspaudio.co.uk/
http://www.headphone.com/index.php
Mark
