External firewire hard drive to go with Mac Mini and USB DAC.
0 Members and 1 Guest are viewing this topic. Read 6904 times.
Dracule1
Hope someone could help me out.  I'm getting the Tranquility USB DAC.  I ordered the Mac Mini and looking to get external 1 or 2 TB firewire hard drive to store my music.  Can anyone recommend a QUIET, RELIABLE external hard drive for the Mini? Thanks.
Audioclyde
I have both a 1.5 TB Ministack (the first one I received was horribly noisy and they had to replace the fan & pwr supply) and a 1.0 TB GTech (fan less). I don't hear a difference in SQ, but the GTech is much quieter. I use the GTech for music file storage & the Ministack only for backup duty.
pardales
Remember that the new MINI's only have a Firwire 800 port. Mine came with a cable that had a Firewire 400 connector on one end and and 800 connector on the other.
I have a 500 GB Lacie drive that is shaped like a black rectangle works fine and is quite. Key is to find a drive without a fan, that runs quiet, and that has the right size and connections for you. I'm not sure brands matter all that much.
I have found the MyBook drives to be very quiet as well.
K Shep
This is my Mac Mini sitting on top of an iOmega minimax 1TB external...same foot print, search Amazon.  With this unit you'll need a FW 400-800.
skunark
I prefer mobile HDDs for the mac mini as there are no power warts to deal with, but they are all typically USB.
WD 1TB USB Mobile Drive -- Fanless, USB powered (no power wart)
http://www.wdc.com/en/products/Products.asp?DriveID=807
WD 2TB FW800/USB Desktop Drive - Fanless
http://www.wdc.com/en/products/Products.asp?DriveID=756
G-Tech(Hitachi) 1TB FW800/USB/SATA Desktop Drive - Fanless, stacks real nice
http://www.g-technology.com/products/g-drive.cfm
Theme here is they are all fanless if you want it to be quiet, the next option would be SSDs but they are pricey when you are in the 1-2TB range.
Keep in mind that you should get "two" of whatever you get for backups (Apple's Time Machine), or use an offsite backup solution (i.e. backblaze)
Crimson
I prefer them as well, but only use FireWire. macsales.com (OWC) has a good selection of FireWire drives.
jtwrace
    • TIPP YouTube Channel
Like many, I use them as well.
Dracule1
Thanks everyone for your suggestions.  Do the Iomega drives have FW connection or USB only?  Audible performance difference between  FW 400 versus 800 - like data drop outs heard as clicks with the slower FW connection?  What is Apples Time Machine?
K Shep
I hope this link helps.
http://www.amazon.com/Iomega-MiniMax-Hard-Drive-FireWire/dp/B0019C4OLY/ref=sr_1_1?ie=UTF8&s=electronics&qid=1272602028&sr=8-1
skunark
Only difference I can make between USB, FW400 vs FW800 are speeds data rate for music is so slow that they don't bottle neck.   It might make ripping a CD or updating tags slightly faster.
Apple Time Machine is set it and forget type backup program that comes free with Mac OS.  Even allows you to restore from a back up if you ever needed to re-install the OS.  For any Linux fans out there it mimic snapshot style backups.
http://www.apple.com/macosx/what-is-macosx/time-machine.html
The time and effort that it took me to rip all of my CDs really encourage me to get a backup and something that is automated.
Dracule1
Re: External firewire hard drive to go with Mac Mini and USB DAC.
« Reply #10 on: 30 Apr 2010, 03:22 pm »
Thanks again for clearing up my confusion.  So I think I will either go with the Iomega or the G-tech drives.  How quiet is the Iomega?  Can you hear it from few feet away?  Anyone have any experience with G-tech?  How quiet is it?
Audioclyde
« Reply #11 on: 30 Apr 2010, 03:27 pm »
I have a 1.0 TB G-Tech; it is quieter than the 1.5 TB Ministack that I also have.  My G-tech sits in an equipment cabinet (with door closed) around 10' away from the listening position---not detectable at all.  With the Ministack (the repaired one), I could sometimes hear its fan in the same setup, although barely after Macsales replaced the fan and pwr supply.
Dracule1
« Reply #12 on: 30 Apr 2010, 06:04 pm »
I'm glad to hear the G-Tech is undetectable in your set up.  But it being in an enclosed rack and listening from 10 feet, one would expect not to hear the drive.  I was worried because one review suggested it is not that quiet for a fanless drive.
skunark
« Reply #13 on: 30 Apr 2010, 06:19 pm »
If i was going to rank my external HDDs (10 being unacceptable):
(fan noise)
10.0 Laci Mini drive
10.0 G-Tech Raid 2TB:      <-- Loudest, meant for video editing though
 9.5  Drobo (USB model)   <-- 3 drive configuration (4th drive is too loud)
(hdd head noise)
2.1 G-Tech Drive 2TB        <-- I think it's slightly louder than the WD
2.0 WD Desktop External 1TB
1.0 G-Tech Mobile, WD mobile drives  <-- least amount of noise
(and no noise for funnies :) )
0.2 Vinyl
0.1 CD
0.0 SSDs/Flash
All is out in the open on a desk...
Dracule1
« Reply #14 on: 30 Apr 2010, 09:18 pm »
Thanks Skunark, your list is very helpful.  How does the Iomega rank on your noise scale?  The largest G-tech mobile drive comes in at 500 GB according to their website.  Where did you find a 1 TB version?
skunark
« Reply #15 on: 30 Apr 2010, 10:48 pm »
I haven't heard the Iomega drive so I'm not sure.   The "1.0" was just the noise ranking not TB size.  I believe only Western Digital have 1TB mobile drives out now current offering is only USB..
Dracule1
« Reply #16 on: 30 Apr 2010, 11:02 pm »
Oh I see.  That makes more sense.  So I'm leaning towards the G-tech...your rating is based on these drives out in the open on a desk...with you sitting next to the desk?   Sorry for the detailed question.  I just want to know if you would be able to hear the G-tech drive from 6 feet away during quiet music passages.  Thanks.
skunark
Yeah they are just a foot or two away and when I work I rarely have music on these days.
skunark
If you do plan to get a time machine drive you could get two different brands and compare.  Make the louder of the two drives the time machine drive which you could turn off during a listening session.  I do like how the gtech drives stack.
skunark
This morning I'm thinking I should have gave the g-tech drive a higher noise rating.    When the mac wakes up the gtech spins up and that is noticeable unlike the WD desktop.  I would want to give it a 3 ranking because of that.
