0 Members and 1 Guest are viewing this topic. Read 5226 times.
I have 2 full range speakers. So, if I dont want to cross them over, how would I hook the the SMS-1? My thought was to run directly to the mains and only run the subs through the SMS-1. Would that work?
Why wouldn't you want to crossover your full range speakers at some point? Crossing over would give better integration with subs as well as freeing your full-rangers and their amplifier from the most demanding part of the spectrum. I wouldn't rule out a high pass filter of around 50-80Hz....
It might free the full range speakers from having to produce the low frequencies, but some believe spreading the bass throughout the room in as many locations as possible is better and provides better -- not worse -- bass integration.
My understanding ( and I could be wrong) is that the SMS-1 only has a fixed high-pass crossover at 80hz.
As I am looking at the SMS-1 and Ausyssey unitls I have some concerns. In looking at the options it appears that the biggest drawback to the SMS-1 is that it does not truly process stereo subs. It nulls them to one signal. Thus for true stereo bass you would need 2 units. The SVS AS-EQ1 does allow for stereo, but also has a 7.5 ms electrical latency which requires either placing your subs 8.4 feet closer to the listening position than the mains, or purchasing a digital cross-over to compensate for the delay. There does not seem to be a single straight-forward solution for DRC of the subs. I was hoping to see how folks have dealt with these issues.
I use 2 SMS-1 units in my HT and like what they do. Using the Outlaw documentation, it is pretty simple and straightforward to use.Can't comment on 2 channel. I have only used the SMS-1 as a measuring device to help me fine tune the built in 11 band EQ in each speaker. George
George,Do you run your mains through the sms-1 or just the subs?
