Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
DAC
DAC
0 Members and 1 Guest are viewing this topic. Read 1319 times.
Charles Calkins
DAC
28 Apr 2010, 11:51 pm »
Hi Guys:
Anybody try hooking their TT up to a DAC and then to the preamp with a phono stage? Just wondering about the results. Better? Same as with no DAC?
OR!!!
Just forgedaboutit!!
Cheers
Charlie
Gopher
Industry Contributor
Re: DAC
29 Apr 2010, 12:28 am »
Whaaa?
I was thinking the same thing, but my turntable is an older model and only has optical out....
viggen
Re: DAC
Reply #2 on:
29 Apr 2010, 04:29 am »
I am pretty sure a record player's signal is not compatible with a DAC's input. However, if you spin the record backwards, the record player might "speak" to the DAC.
doctorcilantro
Re: DAC
Reply #3 on:
29 Apr 2010, 02:10 pm »
Good idea if you have the new direct drives with digital outputs e.g. Stanto, Denon, Numark.
I happen to do it with my ClearAudio, but that's because I'm doing digital RIAA.
DC
The Vinyl Circle
woodsyi
DAC
