Anyone using IcePower with Selah speakers?
0 Members and 1 Guest are viewing this topic. Read 2186 times.
kip_
« on: 28 Apr 2010, 07:16 pm »
I'm toying with the idea of getting a 5-channel IcePower amp for my HT. Was looking at this W4S one:
http://www.wyred4sound.com/webapps/site/74030/117839/shopping/shopping-view.html?pid=339143&b_id=&find_groupid=18048
Thought about going with Emotiva as well but I've heard they can sound bright and thin. Then again Emo is 1/4 the price.
sanjaygolf
Re: Anyone using IcePower with Selah speakers?
« Reply #1 on: 28 Apr 2010, 10:31 pm »
How critical are you with your HT sound? For music I can understand going a different route but with HT when you're just basically going for bigger sound you'd might as well save some money and go with Emotiva.
kip_
« Reply #2 on: 28 Apr 2010, 11:57 pm »
Not too bad. Just mostly looking for higher SPL and more dynamics. Also, the $1500 cost differential could buy a lot of room treatments, and the Emo/treated room setup could well end up sounding better.
hondo
« Reply #3 on: 29 Apr 2010, 01:02 am »
The Wyred4sound will not be thin and bright, it will be dynamic.  There are some Wyred4sound reviews in AudioCircle.  Rick Cullen designs and builds high value products.
kip_
« Reply #4 on: 29 Apr 2010, 01:14 am »
Yeah I don't doubt it, I've read great reviews of W4S on 6moons and other sites, and none of them have described them as bright. I was talking about a few Emotiva reviews I've read. I have a low tolerance for bright components, but my receiver has EQ on it so I can tone it down if needed.
