veneer questions
0 Members and 1 Guest are viewing this topic. Read 2060 times.
[email protected]
veneer questions
« on: 28 Apr 2010, 12:36 pm »
I'm going to be starting some speakers in the neer future and have some questions.
Hax anyone used veneers form Herzog veneers? http://www.veneeronline.com/home.aspx
they offer paper backed veneers and lots, sleeves of raw stock. The raw stock seemes thin, really thin .6mm. Before ordering somethin cheep to play with just wondering if this product is to thin to work with.
thanks marty
hesster
Re: veneer questions
« Reply #1 on: 28 Apr 2010, 04:44 pm »
I used 22m veneer from Oakwood.  They have a huge selection.  The 22m paper backed Veneer has advantages of being easy to trim with a Veneer saw for perfect edges, is still flexible, and it is less apt to sand through prior to applying any finish.
dvenardos
« Reply #2 on: 28 Apr 2010, 05:27 pm »
I bookmarked this seller based on a recommendation from this forum, but haven't used him.
http://myworld.ebay.com/rjfritz123&ssPageName=STRK:MEFSX:SELLERID
If you are looking for the thick raw veneer, these guys have it:
http://www.certainlywood.com/
« Last Edit: 28 Apr 2010, 07:51 pm by dvenardos »
Christof
« Reply #3 on: 29 Apr 2010, 12:29 am »
0.6mm is about 23mil
I buy from Certainly and Oakwood....both are good vendors.
[email protected]
« Reply #4 on: 29 Apr 2010, 01:24 pm »
Thanks for all the responses. I will look at at of the vendors sugested and I'll reporte back on what I do. Should start something next week.
marty
dvenardos
« Reply #5 on: 29 Apr 2010, 03:45 pm »
Christof, do you use raw or paper-backed?
Hank
« Reply #6 on: 30 Apr 2010, 02:51 am »
I've used 10-mil paper-backed for many years.  I've bought almost exclusively from Tape-Ease, but recently a customer wanted samples and after two weeks following my request, I called TE and the guy found the package and said he'd send it next day.  I asked him to ship it to the customer, and over a week later, the customer said: "no samples".  Couple of days later, the samples arrived and they were incomplete and very small.
I contacted Sal at Monster WoodShop in of all places, Brooklyn, NY.  NICE guy - sent me several 8 x 10 samples immediately and has no minimum order:
http://www.monsterwoodshop.com/
I also contacted Formwood and they sent me several 8 x 10 samples immediately. Also, no minimum # of sheets order:
http://www.formwood.com/
[email protected]
« Reply #7 on: 20 May 2010, 03:28 pm »
Thanks for all the replys. I thought I would post a pic of what i bought. I bought it from Herzog, 36 sqft. It came in a bundle of 32 consecutive pieces about 5.5" X 30". I bought it becouse it was inexpensive and I had enough to learn how to veneer. It shipped for $41.
dvenardos
« Reply #8 on: 21 May 2010, 02:19 am »
 :thumb:  Let us know how it goes.
Christof
« Reply #9 on: 22 May 2010, 01:41 pm »
I use both but prefer raw veneer
