Piccolo Scematic Question
0 Members and 1 Guest are viewing this topic. Read 1185 times.
analog97
« on: 27 Apr 2010, 01:56 pm »
I have built 3 Piccolos, all stock.  One of the Piccolos built for a friend has a problem.  :(  No left channel at 20db gain setting, but otherwise A-OK.  I am assuming the resistor at the 20 db gain position has a bad solder joint.  So, I went to the schematic, but was unsure of the location.  Could someone tell me the position of the 20 db gain resistor?   Greatly appreciated!
analog97
Re: Piccolo Scematic Question
« Reply #1 on: 29 Apr 2010, 05:39 pm »
Never mind.  Thanks anyway.  I did it the old fashioned way and checked all the resistors around the gain switch (S2).  Sure enough, R2RB had a bad solder joint....voila!!
