Recommended Apple MiniMac Configuration For Music Server
0 Members and 1 Guest are viewing this topic. Read 1326 times.
nature boy
I would be interested in hearing folks opinions on the best Apple MiniMac configuration for a music server - hard drives (solid state?), etc.  Also what needs to be disabled to get the best possible sound.
I am not sure I will get one, just trying to get an idea of configuration and pricing.  A used rebuilt unit would be fine with me  :D  I still remain undecided on a DAC.  DAC technology and costs still continue to improve by leaps and bounds seemingly every month.
NB
skunark
Re: Recommended Apple MiniMac Configuration For Music Server
« Reply #1 on: 25 Apr 2010, 11:33 pm »
For just a mac mini music server, I would recommend the default option.  The hardware between the different models are the same but perhaps a faster processor and more RAM.  If all you want to do is run a music server, the default is plenty.
For drives, check out this post that I made a while back.
http://www.audiocircle.com/index.php?topic=78352.msg742852#msg742852
I personally feel that solid-state drives are still too costly for my library so I haven't really given them much thought.  But I also use an airport express and apple TV to push the music to a 2-channel and HT setups and keep the mac mini in a different room, and so I have little need for SSDs.   If I had everything in one room, then I would be looking.
Keep in mind that if you do go with the mac mini, get two drives.  One for the Tunes and another for a backup.  You can also look into offsite backups that run about $5/month for unlimited storage.
Since I don't use the Mac Mini to play the music but serve or stream the music to other devices, I just use what is supplied (iTunes).  There's not much I would recommend that you disable, but perhaps the Dashboard (widgets). I actually run Dashboard so I can use "iStat Pro" to monitor CPU load and network utilization.
maxwalrath
« Reply #2 on: 25 Apr 2010, 11:38 pm »
Which companies offer data storage for so cheap?
skunark
« Reply #3 on: 25 Apr 2010, 11:42 pm »
backblaze is what I use.
Jim
maxwalrath
« Reply #4 on: 25 Apr 2010, 11:52 pm »
Thanks Jim  :thumb:
K Shep
« Reply #5 on: 28 Apr 2010, 02:21 pm »
This thread should be moved to the Apple Circle...it will get more attention where it belongs.
