Anyone hear of Ultrabit Platinum Plus?
0 Members and 1 Guest are viewing this topic. Read 1772 times.
heilman
« on: 25 Apr 2010, 09:55 am »
hello All:
I use for all my CDs Ultrabit Platinum treatment. It really enhances my hearing experience. Now I am hearing about a new product called Ultrabit Platinum Plus. It is supposed to be even better. Has anyone here used this treatment, or do you know anyone that has?
*Scotty*
Re: Anyone hear of Ultrabit Platinum Plus?
« Reply #1 on: 26 Apr 2010, 03:12 am »
I would strongly suggest that you rip your CDs to your hard-drive using EAC (free ripping program) in WAV file format. Then burn a CD from the stored WAV file with EAC using a blank Memorex CD-R, BLACK colored blank only, and see what kind of improvement you get.
Thisn may be a bigger improvement than a disc cleaner/treatment. You can also experiment with different types of CD-Rs.The Mitsui makes another good sounding blank CD-R.
http://www.amazon.com/Memorex-700MB-80-Minute-50-Pack-Spindle/dp/B00007JO1D/ref=sr_1_1?ie=UTF8&s=electronics&qid=1272250939&sr=8-1
Scotty
« Last Edit: 26 Apr 2010, 09:45 pm by *Scotty* »
