Danny, would you recommend no rez or blackhole for Usher BE 718?
0 Members and 1 Guest are viewing this topic. Read 1685 times.
Kenobi
Hi Danny,
Since you designed/tweaked the crossover for the Be 718, do you think it would benefit from your no rez or black hole?  What can be expected if either of these options is installed?  Also, how many sheets will be needed and cost?
Thanks in advance,
Kenobi
Danny Richie
You need only one sheet of No Rez, and it is not only less expensive then BH-5, but sounds better too.
It will tighten up the bass response and give you a cleaner sound right up into the lower vocal range.
Kenobi
Hi Danny,
Thank you much!  I'll go ahead and order that sheet of no rez then.  Does it have enough coverage for top/bottom, back and sides for the pair?  If not, please advise priority and thanks much!
Kenobi
Danny Richie
One sheet will do one pair and you might have a few small pieces left over.
