How does the sound change after warm up?
0 Members and 1 Guest are viewing this topic. Read 15286 times.
srb
Re: How does the sound change after warm up?
« Reply #20 on: 23 Apr 2010, 06:50 pm »
Expanding our thought precesses on this matter by thinking beyond our individual calculations, how much energy is going up and out the stack when every amp in the world 250 wpc and greater is turned on 24/7.  Steve, can you get me a number quickly :D .
5.3 YW (yottawatts)
rmurray
« Reply #21 on: 28 Apr 2010, 04:23 pm »
 when my bcd1 is in the standby mode .does this keep things warm enough? :scratch:
95Dyna
« Reply #22 on: 28 Apr 2010, 07:06 pm »
Not in Yellowknife.
Phoenix
« Reply #23 on: 28 Apr 2010, 09:51 pm »
I really think that my B60 sounds better after one hour.
But at the same time I'm convinced I (and almost all of us) would fail in a double-blind experiment with a warm and a cold amp.
BrysTony
« Reply #24 on: 29 Apr 2010, 03:31 am »
System on - check
Relax with glass of wine in hand - check
Yes - Sounds better after one hour!
vegasdave
« Reply #25 on: 29 Apr 2010, 03:47 am »
BrysTony...clever name.
Oh yeah, I bet that helps!
math-geek
« Reply #26 on: 29 Apr 2010, 11:26 pm »
I agree with you on this Robert.  I don't know about the electronics but the Dyns like to have their leg's stretched a bit before serious listening.
Any of you other Cannucks( :D) own Dynaudio speakers.  Take this in jest, my grandfather was from Nova Scotia.
Hi Tom,
The 4B may change slightly but it's a known fact Dynaudio speakers and probably most sound best after being played for a bit, Dynaudio even mention it in their manuals, I always play a few tracks through the 25's before sitting down to some serious listening.
Robert
VOLKS
« Reply #27 on: 30 Apr 2010, 12:30 am »
Personally i dont find the sound change at all after a "Warm Up" on Solid State Gear..........for god sakes Bryston burns the amps in for 100 hrs.......5 minutes or 5 hours after solid state is turned on........i hear no diff in sound quality........now Tube Gear......that is a whole diff story.
rmurray
« Reply #28 on: 30 Apr 2010, 01:28 am »
So none of you fellow members know if a standby mode on the cd player or an amp plays any roll in assisting the warming process! Perhaps James has a opinon. I thought standby helped somehow and if not, then what is the purpose of this feature? :idea:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #29 on: 30 Apr 2010, 05:19 am »
Hi,
Standby just allows for a remote turn on option.
In fact things are getting very restrictive from a power usage turn on feature standpoint - next year the regulations will be no more than 1/2 watt of power for the standby mode.  My quess is you will see a lot of product with no standby feature.
I'm thinking this is maybe one of the issues that killed Plasma TV's?
james
95Dyna
« Reply #30 on: 30 Apr 2010, 12:23 pm »
There is absolutely a significant difference after 30 min. (give or take a few) in sound, soundstage and immaging in my system.  I don't think the initial burn in process and the warm up period after power up are the same subject.  Perhaps the difference is more noticeable with larger amps.
« Reply #31 on: 30 Apr 2010, 01:00 pm »
Hi Folks,
The 'burn in' process we do at the factory is to weed out any potential component failures.
What we do to 'each and every' amplifier is run a 3KHz square wave into it at just below full power into a 'highly reactive capacitive load' (really tough stuff) for 4 days. We cycle the process at one hour 'on' then one hour 'off' repeatedly. This process will weed out what we call 'infant mortality' on the component/parts side and stresses everything in the amplifier to the point whereby potential failures in the customers home is minimised.
james
VOLKS
« Reply #32 on: 30 Apr 2010, 04:57 pm »
James whats your opinion...........Do you personally find an actual diff in sound quality after Bryston products are left on for more then 5 minuntes to an hour or so to "warm Up" or whatever?or do you think maybe we are convincing ourselves there is a diff?lol
« Reply #33 on: 30 Apr 2010, 05:07 pm »
Yes I do... but don't say anything :oops:
james
Stu Pitt
« Reply #34 on: 30 Apr 2010, 07:18 pm »
james
Yes you believe in warm up, or yes you believe we're convincing ourselves?
vegasdave
« Reply #35 on: 30 Apr 2010, 11:19 pm »
Good question.
Napalm
« Reply #36 on: 1 May 2010, 10:28 pm »
If I were James, I would "borrow" engineering's SPICE files then run simulations for 20 celsius and 40 celsius corrected component values. I would look at differences then devise a method to measure them. At this point I would be able to scientifically demonstrate that there is a difference.
Then I'll have to demonstrate that I can hear it. Tough job. I would ask for ABX (as blind AB is BS).
Nap.  :thumb:
« Reply #37 on: 2 May 2010, 12:40 pm »
Hi Stu,
I would say most of the change in sound occurs in the first hour or so IMO. The bias is changing as the amplifier warms up and I think it takes a small about of time for all the components to thermally stabilize.
james
vegasdave
« Reply #38 on: 2 May 2010, 08:04 pm »
Hi Stu,
james
Cool. I'll make a note of that.
Stu Pitt
« Reply #39 on: 3 May 2010, 02:29 am »
Thanks James.  I think about 45 minutes into playing music is when the magic really starts to happen.  Once the knobs on my B60 are toasty warm is when the music flows the best.
