Bryston speaker cables report
0 Members and 1 Guest are viewing this topic. Read 8534 times.
Napalm
Re: Bryston speaker cables report
« Reply #20 on: 24 May 2010, 02:44 pm »
Is the cable bi-wireable?just curious
Why not? As long as you have the terminals on the speaker, you can bi-wire with anything hanger wire included.
Nap.
dj_seraphim
« Reply #21 on: 24 May 2010, 04:57 pm »
Out of interest is the cable Van Damme 2x4.mm code 268-504?
Napalm
« Reply #22 on: 24 May 2010, 05:07 pm »
It's the 268-506 2x6mm. At least that's what mine reads.
Nap.  :thumb:
Deftone
« Reply #23 on: 30 May 2010, 04:41 am »
Nap.
Nap,as i can see,the 4b only have one binding post for the SC.How do i go about bi-wiring the 4b?Do i need to get 2 diffrent connectors for the post,that is one spade and one banana?Do they do 2 to 4.I mean 2 from the amp and 4  for the speakers,just like the chords does.Thanks.
Napalm
« Reply #24 on: 30 May 2010, 04:53 am »
The easiest way is to insert 2 cable in one banana or crimp 2 of them in one spade. At the other end you'll have two bananas or 2 spades.
However personally I'm not convinced of any benefit of bi-wiring. If you think cables are an issue just replace with thicker gauge.
Nap.  :thumb:
