Audio/Video Gear and Systems
The HiRez Music Circle
ted_b
Standard Convention - Sample Rate/Bit Depth or Bit Depth / Sample Rate
0 Members and 1 Guest are viewing this topic. Read 1444 times.
KiwiBobs
22 Apr 2010, 06:08 am »
Sometimes I see 96/24 and sometimes I see 24/96.
Is there a standard correct convention?
ted_b
Facilitator
"we're all bozos on this bus" F.T.
Re: Standard Convention - Sample Rate/Bit Depth or Bit Depth / Sample Rate
22 Apr 2010, 11:40 am »
I've always (ok, 90% of the time) seen it as 24/96 (for your example) IOW, bit depth then sample rate. That's how the pro recording guys speak it as well.
ted_b
