Deal of the day
0 Members and 1 Guest are viewing this topic. Read 5565 times.
Danny Richie
Re: Deal of the day
« Reply #20 on: 30 Apr 2010, 02:41 pm »
What are you planning on using in the V2 kit for hooking up the subs to the amp?
I hook the wire leads that are already on the amp straight to the lower woofer then run a jumper from the bottom woofer (easy since there are two terminals for + and -) to the top woofer. No binding post needed either.
Also, these are my first OB subs are they supposed to be wired out of phase. I seem to recall that.
Nope, just wire them normally. If you need to flip the phase then there is a 180 degree phase switch right on the amp.
dvenardos
Re: Deal of the day
« Reply #21 on: 30 Apr 2010, 04:27 pm »
The W-frames are only 24", I think maybe I will build a slide out amp enclosure for them to sit on and then drill a hole in the bottom of the W-frame to pass through the wires from the amp. That way I can put grills front and back.
Danny Richie
Re: Deal of the day
« Reply #22 on: 30 Apr 2010, 05:07 pm »
Just remember that if you drop them into a W frame and flip one woofer around facing the other direction to be sure and flip its polarity too.
dvenardos
Re: Deal of the day
« Reply #23 on: 30 Apr 2010, 05:27 pm »
Ah, that is what I was thinking of. Thanks.
