Does anyone use Groove Glide on their records?
0 Members and 1 Guest are viewing this topic. Read 2453 times.
steve k
« on: 19 Apr 2010, 12:58 am »
I was wondering if it quiets the surface noise any on older recordings. I've always been concerned that it will build up on the stylus.
steve
bretdago
Re: Does anyone use Groove Glide on their records?
« Reply #1 on: 19 Apr 2010, 11:34 am »
I use groove glide on occasion, usually on records that are less than perfect. It does seem to cut down on surface noise and as of yet I don't see or hear the effects of any buildup on the cartridge. I would buy a can again when this one is depleted.
steve k
« Reply #2 on: 19 Apr 2010, 12:47 pm »
Wayner
« Reply #3 on: 19 Apr 2010, 06:20 pm »
Is this stuff a liquid or a very fine powder? How is it applied and managed?
Wayner
baldrick
« Reply #4 on: 21 Apr 2010, 06:30 pm »
It's a dry lubricant that is carried by an evaporating solvent.Apparently it does no harm to the record.  I know that Sheffield Labs used to have a Gruv-Glide endorsement on their record sleeves back in the day.Although I've never tried (I've been loyal to LAST's record preservative for decades) it I have never heard any bad stories about it, and by all accounts it does improve the sound.
Here's how it works:http://www.gruvglide.com/PRODUCTS.html
rollo
  • Rollo Audio Consulting -
« Reply #5 on: 21 Apr 2010, 07:56 pm »
 NOPE. Ivor won't let me. I'm Linned. Actually never had a need. Just keep those records clean and be done. IMO any liquid, or powder will work its way up the cant. and cause a problem with the assembly. Again my opinion.
charles
orthobiz
« Reply #6 on: 23 Apr 2010, 02:14 pm »
charles
If you're Linned, then you're probably using the felt mat, too...
Paul
rollo
« Reply #7 on: 23 Apr 2010, 03:42 pm »
Paul
  Nope I snuck in a Herbie matt. SHHHH ! :nono: Ivor is watching. Oh and don't forget the proper side of the felt matt [ the rough side]  :duh:.
charles :thumb:
Delta Wave
« Reply #8 on: 24 Apr 2010, 01:07 pm »
I use it, there is a slightly noticeable, improved quietness in sound but it is outstanding for subduing static. I've never had an issue with any residue buildup on my styli and I've used it for a few years now.
2gumby2
« Reply #9 on: 25 Apr 2010, 11:13 am »
I have some new Gruv-Glide that I put up on the Audiocircle For Sale: Accessories page. Take a look.
http://www.audiocircle.com/index.php?topic=80472.0
twitch54
« Reply #10 on: 26 Apr 2010, 12:11 pm »
I used it during the winter months as way to cut down on static build up....it worked....but what worked better was finally getting my low humidity under control... :duh:
Wayner, it comes in an aresol can with a 'pad applicator'....does it perform better than treating with 'LAST' ?? ...I can't honesty say that I heard any improvement.
