Virtue One.2 Sonicap version
0 Members and 1 Guest are viewing this topic. Read 3396 times.
dvenardos
« on: 17 Apr 2010, 09:13 pm »
Danny,
Are you still planning on offering the One.2 with sonicaps? Just curious.
Danny Richie
Re: Virtue One.2 Sonicap version
« Reply #1 on: 17 Apr 2010, 11:09 pm »
45 units are being made that way from the factory. I shipped them the caps.
roymail
  • Roy in TX
« Reply #2 on: 25 Apr 2010, 02:06 am »
Will there be a price difference?
How well will this amp perform with the N2X?
Danny Richie
« Reply #3 on: 25 Apr 2010, 02:37 am »
A little.
It won't play it real loud, but it will sound great.
roymail
  • Roy in TX
« Reply #4 on: 25 Apr 2010, 09:28 pm »
So the N3 would be a better match for the Virtue w/Sonic cap amp?  :wink:
dvenardos
« Reply #5 on: 25 Apr 2010, 10:26 pm »
Depends on how loud you listen. I had the Neo 2x demo unit here and had no issue using it with my Virtue Two, but I don't listen at high SPL.
roymail
  • Roy in TX
« Reply #6 on: 25 Apr 2010, 10:29 pm »
I suspect room size and ceiling height also comes into play here.
Danny Richie
« Reply #7 on: 26 Apr 2010, 02:00 am »
Room size and listening distance are certainly in play, but the higher sensitivity of the N3 will go a long way.
brother love
« Reply #8 on: 26 May 2010, 01:10 pm »
Danny,
Any status update on delivery & price for the 45 One.2 units you ordered w/ Sonicaps?  I assume we are talking about the wunderbar Platinums, or Gen II's?
Also, in keeping w/ the small form set-up ... Seth now offers a 28v 5 amp & 7 amp (2) battery kit vs. the (4) battery kit you offer. I suppose they all originate from Gary Dodd, so any chance you will be getting those smaller footprint kits as well?  Edit:  Nevermind re: this question. Virtue Audio shows these 2 battery options are from GR Research; but they don't show up on your website...
Thanks for any info you can provide.  I'm very interested as I'm sure are others on here.
Danny Richie
« Reply #9 on: 26 May 2010, 07:16 pm »
Those new units coming have Gen.1 Sonicaps.
The new smaller battery kits will be up on the web site as soon as I can get to it. They actually drop ship from Dodd Audio as Gary is the one that makes all the wiring harness for it all.
Hang in there.
brother love
« Reply #10 on: 22 Jun 2010, 01:07 pm »
Danny,  re: the Sonicap Gen I selections ...
Did you experiment w/ the Sonicap Platinums or any Sonicap bypass configurations ?  Or was the real estate too limited, you wanted to keep the cost down, or just simply law of diminishing returns ?
I'm auditioning a One.2 now as part of the AC tour (super nice little amp ! ).  If the 80 Hz jumper is used to incorporate a sub,  then only the (2) .1uF capacitors come into play. I was curious if the (2) 2.2 uF capacitors are removed & the added room allows for larger .1 uF capacitors, if the Platinums would be of added benefit for the $58 cost vs. say $11 cost for the Gen I ?
vvv  Thanks Danny !  vvv
« Last Edit: 22 Jun 2010, 08:03 pm by brother love »
Danny Richie
« Reply #11 on: 22 Jun 2010, 06:41 pm »
....you wanted to keep the cost down,
Yep, just keeping the cost down. The end user can upgrade them if they want.
They would bring the performance level up a notch in either the by-pass position or in replacing the main cap if used with a sub.
