MARANTZ REFERENCE SERIES SA-15S1 SACD/CD PLAYER
0 Members and 1 Guest are viewing this topic. Read 2128 times.
wil801
« on: 17 Apr 2010, 12:04 am »
I AM SELLING A MARANTZ REFERENCE SERIES SA-15S1 SACD/CD PLAYER. IT IS IN ABSOLUTELY FLAWLESS LIKE NEW CONDITION!! NO SCRATCHES, DENTS, DINGS, OR IMPERFECTIONS OF ANY KIND. IT COMES WITH A REMOTE CONTROL AND OWNERS MANUAL. A DETACHABLE POWERCORD IS ALSO INCLUDED.THIS IS A VERY HEAVY SACD PLAYER WEIGHING 29.7 POUNDS. IT IS INDEED A WORK-OF-ART.
HERE ARE SOME SPECS: DISC CAPACITY: 1, CURRENT FEEDBACK ANALOG STAGE, PLAYS: SACD STEREO, CD, CD-R/RW, POWER TRANSFORMER: SHIELDED EI, ZERO IMPEDANCE PLATE, DOUBLE LAYERED BOTTOM PLATES, HDAM, AUDIO DAC: 192kHz/24BIT, DISPLAY ON/OFF, HEADPHONE OUTPUT, UNBALANCED L/R OUTPUTS, DIGITAL OUT, DIGITAL IN, SACD FORMAT: 1-BIT DSD, SAMPLING FREQUENCY: 2.8224MHz, DYNAMIC RANGE: 111db, FREQUENCY RESPONSE: 2Hz-50kHz, THD: 0.002%, CD FORMAT: 16BIT LINEAR PCM, SAMPLING FREQUENCY: 44.1kHz, DYNAMIC RANGE: 100db, FREQUENCY RESPONSE: 2Hz-20kHz, COLOR: PLATINUM, FRONT PANEL: ALUMINUM, REMOTE: ALUMINUM TOP, POWER: 120v, WEIGHT: 29.7LBS, DIMENSIONS: 17 5/16" x 4 15/16" x 17 1/2".
*HIGH PERFORMANCE D/A CONVERTERS FOR DSD/PCM SIGNAL PROCESSING
*DISCRETE ANALOG AUDIO CIRCUITRY WITH MARANTZ ORIGINAL HDAM
*DISCRETE HEADPHONE AMP WITH INPUT BUFFER
*HIGH ACCURACY SYSTEM CLOCK CRYSTAL
*OVER SIZED SHIELDED EI CORE TRANSFORMWER
*NOISELESS LCD DISPLAY
*SHORTER SIGNAL PATH CIRCUIT BOARD CONSTRUCTION
*DOUBLE LAYERED BOTTOM PLATE
*PLAYS SACD/CD, CD-R/RW
*USES CS4397 CRYSTAL
*BLACK SURFACE TO PREVENT ANY DISTORTION OF THE LASER LIGHT
Came in original factory packaging.
Price is $650 firm.
