Audio/Video Gear and Systems
Home Theater and Video
Bob in St. Louis
Need help with Toslink splitter
0 Members and 1 Guest are viewing this topic. Read 1330 times.
werner52
16 Apr 2010, 05:02 pm »
Hello, I'm needing to split a toslink 1:2 and was looking at these two devices. Can anyone recommend either or? Thanks.
http://www.markertek.com/Audio-Equipment/Audio-Interface/Audio-Splitters/Gefen-Inc/GTV-DIGAUD-142.xhtml?GTV-DIGAUD-142
http://www.markertek.com/Routers-Switchers-DA's/Video-Distribution/TLDA-1.xhtml?TLDA-1
gerald porzio
Re: Need help with Toslink splitter
16 Apr 2010, 05:39 pm »
Haven't used either, tho Frank VanAlstein recommended one of the Inday video switchers. You might try his forum.
gerald porzio
Reply #2 on:
16 Apr 2010, 05:41 pm »
http://www.inday.com/
I got this link from that forum.
werner52
Reply #3 on:
16 Apr 2010, 07:28 pm »
gerald porzio
- Thanks.
rudy99
ยป
Reply #4 on:
19 May 2010, 07:31 am »
ive got the square one that splits either toslink or coaxial into toslink and coaxial at same time,, super handy,, but i dont use it much
Bob in St. Louis
