Can you increase the voltage of the Bugle Power Supply
0 Members and 1 Guest are viewing this topic. Read 1230 times.
bigfishe
I need 18volts
poty
Re: Can you increase the voltage of the Bugle Power Supply
« Reply #1 on: 16 Apr 2010, 05:22 pm »
Use the transformer TE70024, regulators LM78M18 and LM79M18.
hagtech
« Reply #2 on: 17 Apr 2010, 07:02 am »
You can also change the 10 ohm resistors to 1 ohm.  That gives you a little more headroom.
jh
