7BSST `s
0 Members and 1 Guest are viewing this topic. Read 3136 times.
dukeofearl
7BSST `s
« on: 15 Apr 2010, 06:52 am »
Hi all
ive had my 7BSSTs for a few weeks now they are truly awesome the extra detail in everything i play through them is amazing ,,like others have said you put a  well known cd in and its like " i never knew that was there !!
I am thinking now whats it going to sound like when i upgrade to a cd player ( playing cd through blu ray player at the moment) and my cables using very cheap speaker and phono s for now and the preamp !! .
I would like to get the 12 v triggers connected up but my pre amp (pioneer SCLX81 has like headphone sockets see photo (click on rear view of photo to enlarge)
http://
http://www.google.co.uk/imgres?imgurl=http://www.avland.co.uk/pioneer/sclx81/rearlrg.jpg&imgrefurl=http://www.avland.co.uk/pioneer/sclx81/sclx81.htm&usg=___3lAqAAAIQeyItakfy1KGIGq_sY=&h=1800&w=3804&sz=1196&hl=en&start=6&itbs=1&tbnid=gjOD6NFO1R4EiM:&tbnh=71&tbnw=150&prev=/images%3Fq%3Dsclx81%26hl%3Den%26sa%3DG%26tbo%3D1%26gbv%3D2%26tbs%3Disch:1
not too sure what cable i should get and how to connect it up can anyone advise please
thanks
mark..
canucks0
Re: 7BSST `s
« Reply #1 on: 15 Apr 2010, 11:44 am »
Mark,
 For triggering, buy a 1/8" stereo microphone cable and cut off one of the ends about 6". You will see three wires. Take cheap 18g speaker cable and connect one speaker cable wire to the white wire on the cutoff end and the other wire to the 2-wire twist of the red/ground on your microphone cable end. I have a Mcintosh processor with the same kind on trigger input. Now when I put the pro on it turn on my 7B SST2's and my 6B SST2 just like a chain reaction. Hope this helps.
95Dyna
Re: 7BSST `s
« Reply #2 on: 15 Apr 2010, 12:52 pm »
Hi dukeofearl,
I installed my new 7BSST2's with the new transformer last June and share your opinion of them.  For what its worth on the CD/cable front I have the Esoteric X-05 and WireWorld Silver Eclipse 6 SC's and balanced IC's.  I love the combination with the 7's.  The cables made an immediate impact in enhancing what you are already experiencing with the 7's and the X-05 predictably plays a bigger role in what you hear off your CD/SACD's than the 7's will.  However if budget and or lack of interest in SACD is in play the Bryston BCD-1 is a no brainer choice.  I spoke with David Salz the president of WireWorld before the purchase and he advised me that Bryston uses WireWorld cables extensively in their show demos.  I bought the X-05 and cables at the same time from a dealer who gave me an outstanding deal for the combo purchase.  If your're interested PM me for the details.
I don 't use the 12 V triggers as I have little patience for adding to the quagmire of cables behind my cabinet and actually enjoy the tactile interface with my gear each time I fire up.
Bill
95Dyna
Re: 7BSST `s
« Reply #3 on: 15 Apr 2010, 02:53 pm »
Bill
Sorry, I just discovered that you are in the UK so my dealer in the US won't be of any help.
gerald porzio
Re: 7BSST `s
« Reply #4 on: 15 Apr 2010, 03:35 pm »
"I spoke with David Salz the president of WireWorld before the purchase and he advised me that Bryston uses WireWorld cables extensively in their show demos."
I would have thought that Bryston would have used their own cables. Why use another mfg. when Bryston sells their own brand? Perhaps James will explain.
  • The Demo is Everything!
    • http://www.bryston.com
Re: 7BSST `s
« Reply #5 on: 15 Apr 2010, 04:22 pm »
Hi Gerald.
We usually share rooms with other companies at shows so the cables used will vary from show to show.
james
Napalm
Re: 7BSST `s
« Reply #6 on: 15 Apr 2010, 04:35 pm »
Mhhh my quest for speaker cables has come to an end. I ordered them from Bryston an hour ago. If they're good enough for professional studio installation, they're surely good enough for my family room.... My agony is now over.
Nap.  :thumb:
vegasdave
Re: 7BSST `s
« Reply #7 on: 15 Apr 2010, 08:58 pm »
Sounds good. I hope you will be happy with them.
dukeofearl
Re: 7BSST `s
« Reply #8 on: 16 Apr 2010, 07:15 am »
Hi thanks for the advise i will try and get the mic cable this weekend ,,,  as for speaker cable what type of wireworld cable do you use i was thinking along the lines of kimber 8 TC has anyone tried and tested this with brystons ?
for the blu ray player to the pre amp i have bought a set of these
 http://markgrantcables.co.uk/shop/index.php?main_page=product_info&cPath=43_1&products_id=165&zenid=vs8j3umn84mo1hhbmo7vrspv45
although from the preamp to the brystons i only have cheap component video cable s i had at home i will get another set of these soon ..
redbook
  • the music is the blood...........
Re: 7BSST `s
« Reply #9 on: 16 Apr 2010, 02:12 pm »
Speaking of Bryston cables.... Does Bryston still make their balance units from VanDamme wire. If so which one. I see that VanDamme has various grades
Re: 7BSST `s
« Reply #10 on: 16 Apr 2010, 03:02 pm »
Hi,
Yes we use one of the VanDamme very low noise microphone shielded cables for our XLR Balanced cables and install our own connectors.
james
redbook
Re: 7BSST `s
« Reply #11 on: 16 Apr 2010, 07:15 pm »
Thanks James. I will order a set . Is shorter the better in this case or makes no difference? I'm talking about 3 feet!  :singing:
Re: 7BSST `s
« Reply #12 on: 16 Apr 2010, 10:16 pm »
With balanced cables length is not a concern.
james
werd
Re: 7BSST `s
« Reply #13 on: 17 Apr 2010, 02:27 am »
Hi dukeofearl,
I
Bill
Yah me too, thats exactly how i feel about it.
rmurray
Re: 7BSST `s
« Reply #14 on: 17 Apr 2010, 04:55 pm »
I started using  balanced connects between my CD-1 and the BP25. Everything improved over the very good Nordost Redawn RCA's. What more if I balance wire to the power amp?.....:.can hardly wait! :hyper:
