What is my best choice between 1V and 2V gain settings?
0 Members and 1 Guest are viewing this topic. Read 1674 times.
Waker
James and others, can I get a clinical on the proper use of the gain selections on my new 7BSST2?  ? I have followed the manual's recommendation of 2V because I am using the balanced inputs on the amps.  The front end is just one piece--a modified Wadia 861 CD player.  There is no outboard pre-amp, just the player, which needs to play between 70 and 100 on its digital volume scale of 0 to 100.  This range has worked well for me in terms of listening levels, and is recommended by Wadia in order to send all of the digital information.  I am also advised by my audio dealer to not add a pre-amp unless needed for more sources. They tell me the Wadia has a fine output section. I am using Magnepan 3.6Rs, which are 4 ohm. Please evaluate this situation so I can sleep at night...... :)
gerald porzio
Re: What is my best choice between 1V and 2V gain settings?
« Reply #1 on: 12 Apr 2010, 07:09 pm »
Since the Wadia is designed to be used w/o a preamp, & you are w/in Wadia's range for not losing any bits (info), you can rest easy. No problemo.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 12 Apr 2010, 07:10 pm »
What's the maximum output voltage of the Wadia?
james
Waker
« Reply #3 on: 12 Apr 2010, 07:15 pm »
Not sure on that--anyone else have this figure?
werd
« Reply #4 on: 12 Apr 2010, 08:20 pm »
Just go with what sounds best. You won't damage anything unless you toggle it while its too loud. Enjoy both.
« Reply #5 on: 12 Apr 2010, 08:30 pm »
Got this from a 2002 Stereophile review:
The maximum output level at 1kHz was 2.13V with Filter A from both balanced and unbalanced outputs, this dropping by 1dB to 1.9V when the filter was switched to type B. Filter C raised the level by 0.2dB compared with B, to 1.94V. These differences may be small, but because they cover the entire audioband, they will be audible.
james
