Lip Sync Issues......
0 Members and 1 Guest are viewing this topic. Read 1251 times.
OlesonMD
« on: 12 Apr 2010, 12:45 pm »
My Panasonic DMP-BD85 seems to have audio/video sync issues.
The audio is suffering from a barely noticeable delay. The player has audio adjust, but in delay only which makes the situation worse. What I need is an audio advance of a micro-second or two.
This is worse on some DVD's and Bluray's than on others. Sometimes the audio/video sync is fine. Sometimes the audio delay is bothersome.
The video is over HDMI, and the audio is optical cable. My NAD pre/pro is not HDMI friendly!
Any suggestions?
Mr Peabody
Re: Lip Sync Issues......
« Reply #1 on: 22 May 2010, 06:01 am »
Have you used other BDP's?  I suspect the problem is not with the Panasonic but with audio and video leaving taking different paths.  If your NAD has component in/out you might try that for video.  Any difference in picture quality may or may not be noticeable.  You could also try a different audio connection like coaxial to see if it would make any difference.  I have no reason really to believe it would but to eliminate an annoying problem and prolong expense of preamp upgrade anything is worth a try, right :)
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #2 on: 25 May 2010, 03:36 pm »
Possible solutions are to change cables, (check if they are in good conditions) update the firmware if possible. I also heard about some lip sync correction devices, check:
http://www.lipfix.com/lip_sync_error.html
