Bryston 2B-LP with 12V trigger input
0 Members and 1 Guest are viewing this topic. Read 1230 times.
quietdragon
« on: 11 Apr 2010, 02:27 pm »
I've been looking for a used 2B-LP with 12V trigger input for a small system without much success.
The manual says that the 12V trigger is optional.
I'm beginning to suspect that most 2B-LP units do not have the 12V trigger.
What percentage of the 2B-LP units out there have the 12V trigger ?
brucek
Re: Bryston 2B-LP with 12V trigger input
« Reply #1 on: 11 Apr 2010, 02:37 pm »
You could use one of these devices. Others sell them also - Panamax, etc.
brucek
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 11 Apr 2010, 06:46 pm »
Hi - I would say less than 10% in the past.  The new 2B LP's have the trigger as standard.
james
