7 X 10 inch car speakers for OB? Is this LO-FI heresy?
0 Members and 1 Guest are viewing this topic. Read 2191 times.
grantnsw
Hi,
Car speakers on OB...is this LO-FI heresy?
http://india.kenwood.com/products/car/speakers/kfc-hq718ex/spec.html
no idea what the T/S parameters are (except stated 3 Ohms) but Qts must be about 1?
I was just wondering about the sound quality and distortion et cetera.
Any ideas? They seem cheap enough.  cheers, Grant
 :oops:
opnly bafld
Re: 7 X 10 inch car speakers for OB? Is this LO-FI heresy?
« Reply #1 on: 11 Apr 2010, 01:09 pm »
I have the Kenwood dual cone 6x9s and they don't sound too bad.
http://www.kenwoodusa.com/Car_Entertainment/Speakers/6''_x_9''_Speakers/KFC-6950S
I didn't see them on the India site but they have these:
http://india.kenwood.com/products/car/speakers/kfc-1651s/index.html
The dual cones should be even cheaper than the 3 ways so they might be worth a try.
Lin
grantnsw
« Reply #2 on: 11 Apr 2010, 01:47 pm »
Hey Lin,
Thanks for the links. So car speakers might work OB then!     woohoo  :D
Yes its all about budget here, but I did find these:
http://www.ryda.com.au/Pioneer-TS-A2003i-Car-Speakers-p/tsa2003i.htm
again, a bit expensive and no T/S specs, so maybe your Kenwood 6by9's might just do the trick.
I have two 12" high Qts woofers, so I thought OB with car full-range might work.
Very much appreciated, Grant
