0 Members and 1 Guest are viewing this topic. Read 10219 times.
Hi Richard...I'm close to pulling the trigger on Airport Express. [I sold a Wadia 830 to go Macbook and Red Wine Audio DAC via USB -- so I'm on board with your streaming audio philosophy.]I've been researching the topic and this is the first time I've seen anyone mention that a device needs to be attached to the modem. What device is that? Thanks, Kent
The device connected to the modem is the wireless router to create your wireless network that the Airport Express is connecting to. If you already have a wireless network set up, you already have that device.
If it would achieve my aim, I could use iTunes.Is there a handheld device, phone, or something, that could act as a remote control to my laptop, which I want to leave hardwired to my amplifier? If all I can achieve is to have to select the music at the laptop, and then sit down and press play from this "remote", I would be happy.
1) An iPod Touch works as a remote control for iTunes. Does it also act as a remote control for general functions on a MacBook (like turning volume up and down in Preferences > Sound)?
2.) I need to order about 4 mac / ipod items. Are there any online sites that offer discounts on current products? PM please if this is not appropriate for AC.
The "Remote" application will control the volume slider within iTunes. There may be other downloadable applications to control other Mac parameters outside of iTunes. Although prices are fairly tightly controlled, Amazon and some others have up to 10% off on some of the Apple items, including iPods. Steve
Airport Express uses 2 small devices... one connects to the modem and the other connects to our amplifier with RCA cables (the device plugs into an electrical outlet). You can record all of your CD's as you listen to them... it is very fast!!!
Thanks. I'm thinking of going to a tube USB DAC with volume control. I'm trying to figure out if I could control the volume for DVDs runing throught the Macbook as a way to eliminate a pre from the config. I know it's a compromize., but 2ch is my top priority.
There is an app you can buy, "Rowmote" ($.99), that duplicates the Apple hardware remote, and should provide system volume as well as transport controls for DVD play. There is another app, "Rowmote Pro" ($4.99), that provides additional system controls, including trackpad and keyboard. Steve
