4B SST2 - Should it be dead quiet?
0 Members and 1 Guest are viewing this topic. Read 2649 times.
jaxwired
« on: 10 Apr 2010, 11:47 am »
Hi all,
I have owned a 4B SST2 now for a couple months and I've noticed that when I turn it on, before I start playing music, the amp emits a very subtle hum.  I'm talking extremely subtle here.  I have to put my ear right up to it to hear it.  My question for everyone is, is this normal?  Of course it has no impact on the sound when music is playing.  I can't even hear it when it's dead quite in the room unless I put my ear right up to the amp.  I'm just wondering if it should happen at all.
BTW, I love this amp.   The sound is simply amazing.  I cannot imagine upgrading for years.  Instrument separation is the best I've ever heard.
rob80b
Re: 4B SST2 - Should it be dead quiet?
« Reply #1 on: 10 Apr 2010, 12:12 pm »
"4B SST2 - Should it be dead quiet?"
Only when it's turned off.
Not to be funny, but the 4B does have a pair of hefty transformers so it's actually surprising it's as quite as it is. Line hum is another issue but I'm not about to go there.
Robert
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 10 Apr 2010, 01:11 pm »
Hi all,
Yes it is normal and as Rob said given the size of the transformers we use they are very quiet.  Our transformers are proprietary and specially wound and designed to be very quiet.
james
werd
« Reply #3 on: 10 Apr 2010, 04:48 pm »
My 14B is remarkably quiet for its size. A non issue really.
vegasdave
« Reply #4 on: 10 Apr 2010, 08:15 pm »
Hi all,
What do you think of the BP6?
Laundrew
« Reply #5 on: 10 Apr 2010, 08:28 pm »
The only noise that my amplifiers emit is during power-up and it is of a very short duration “buzzing.” The 28Bs that I auditioned did not make this noise during power-up, but I believe that they were the “pre” new transformer models.
Be well…
« Reply #6 on: 10 Apr 2010, 09:17 pm »
Be well…
Hi Laundrew,
That 'buzz' is the 'softstart' circuit.  When large transformers turn on they can draw 3 to 4 times the current they need when operating so the softstart circuit prevents your circuit breakers in your fusebox from tripping.
james
Laundrew
« Reply #7 on: 10 Apr 2010, 09:59 pm »
Hi Laundrew,
james
The calm before the storm…
 :wink:
Thanks James :thumb:
Be well...
Napalm
« Reply #8 on: 10 Apr 2010, 10:00 pm »
I'd say that if you don't need balanced outputs, it's the next best thing to a BP26.  :eyebrows:
Nap.  :thumb:
predrag
« Reply #9 on: 11 Apr 2010, 04:13 pm »
IMO the one second buzz on turning on lets you know there´s a powerplant here!
My 7`s are in operation dead quiet and are quite an achievement from engineering point.
Bryston is the most quiet electronics that I ever heard (apart from BCD1 drawer).  :lol:
95Dyna
« Reply #10 on: 12 Apr 2010, 12:53 pm »
Ditto.  My 7's with the new transformers are dead silent after the aforementioned startup buzz.  Now if I could only get my Esoteric X-05 to stop humming on track one of every disc.......
