Bryston SP 1.7 Turn Off Issue
0 Members and 1 Guest are viewing this topic. Read 1158 times.
donny619
« on: 9 Apr 2010, 05:19 pm »
Does anyone who owns a SP 1.7 have the same issue as I do? About 80% of the time, when I switch it off, the unit does not power down. I have to do it with the remote. It always turns on using the switch but it's spotty turning off. Was looking for a quick fix without having to send it in. Also, why is it doing this?
brucek
Re: Bryston SP 1.7 Turn Off Issue
« Reply #1 on: 9 Apr 2010, 07:02 pm »
The power switch and the dynamic range switches on the front panel are quite poor. Better quality switches should have been chosen here IMO. Mine are both intermittent and I have this problem also. I just use the remote.
brucek
jethro
« Reply #2 on: 9 Apr 2010, 10:06 pm »
My switches work fine. I have an upgraded SP-1 to SP-1.7. I can't remember if they used new switches during the upgrade.
