wiring 18" sub in its box
0 Members and 1 Guest are viewing this topic. Read 1996 times.
MikeCTM2
« on: 9 Apr 2010, 01:52 am »
Hi  I'm wanting to play this 18 soooo bad but i don't know how to wire it up in the box.
The system is ready to play it
I already have a 15 hittin off the system.  I wired this up prolly back in 2003
I wanna get this Maelstrom mk1 (Adire Audio) moving now
This would be off a 250W Parts Express plate amp that's 4 ohm.
The 18 is dual voice coil.  There's two wire push-button terminals on each side.
Can i get a link to a schematic for this?
NEO Dan
Re: wiring 18" sub in its box
« Reply #1 on: 9 Apr 2010, 03:12 am »
Your driver has dual 8Ω coils so wire them like this:
MikeCTM2
« Reply #2 on: 14 Apr 2010, 12:54 am »
Thank you very much  That's what i'll do     So now i know  my Sub has two eight Ohm Coils.  I'll wire Parallel for a 4 Ohm final load.
I got a QSC RMX 1450 pro audio amp.  In its bridge mode it does 900 watts to an 8 Ohm load.  I thought that is what the Driver was when i obtained the amp.  i also have an adire audio Tempest in a ported enclosure.  I supposed now i should use the QSC to push both Adire Subs.  That's instead of using the QSC bridged for the 18 and a 250watt parts express plate amp for the 15.
 :thumb: case closed
« Last Edit: 14 Apr 2010, 08:18 pm by MikeCTM2 »
JimJ
  • Ut Prosim
« Reply #3 on: 5 Jul 2010, 11:31 pm »
I know this might be bringing it back from the dead, but I wouldn't use both subs. Mixing different size drivers playing the same frequency range is a bad idea.
Speedskater
  • Kevin
« Reply #4 on: 23 Jul 2010, 02:29 pm »
Not necessarily, Earl Geddes suggests that it's a reasonable solution, especially if that what's available.  But if stating from scratch, then other paths may be better.
In the earlier posts, paralleling voice coils and bridging amps don't mix.
