wiring a sub in its box
0 Members and 1 Guest are viewing this topic. Read 1150 times.
MikeCTM2
« on: 9 Apr 2010, 01:42 am »
Hi  I am soo stumped on how to wire this Adire Audio Maelstrom Dual Voice Coil Sub.
I have the 250W parts express plate amp that's four ohm.
I think the Sub is four ohms too.   Can i get a link to a wiring schematic?  Adire Audio isn't around anymore.
Thanks!   :D
HAL
Re: wiring a sub in its box
« Reply #1 on: 9 Apr 2010, 01:48 am »
According to the driver specs it is a dual 8 ohm voice coil.
If you have two 8 ohm voice coils, how would you get 4 ohms from that?  Look at what happens when you parallel and series connect two 8 ohm resistors and you will find your answer.  Once you have the answer then connect the amp to the result.
Duke
    • http://www.audiokinesis.com
« Reply #2 on: 9 Apr 2010, 01:52 am »
My (highly fallible) recollection is that the Maelstrom came with either dual 8-ohm voice coils, or dual 4-ohm voice coils.
If you have dual 8-ohm voice coils, wire them in parallel to get 4 ohms.  The red wire from your plate amp goes to both of the + inputs on the sub, and the black wire from your plate amp goes to both of the - inputs on the sub.
If you have dual 4-ohm voice coils, wire them in series to get 8 ohms (the alternative is in parallel, but that would give you a 2-ohm load and cook your amp).   The red wire goes to a + input.  Then use a jumper wire to connect the - input next to where the red wire is to the other + input.  Then the black wire goes to the other - input.
If you don't know, wire them in series for now. At least that way you won't cook your amp.
Duke
S Clark
« Reply #3 on: 9 Apr 2010, 03:02 am »
Can you get a measurement on that woofer?  Even a DC resistance is better than nothing.  Until you know what you are dealing with, I agree with Duke that you better run the voice coils in series to protect your amp.
