0 Members and 1 Guest are viewing this topic. Read 8770 times.
845's are the best, because all the other numbers are lower.
Great post Josh I haven't heard most of the tubes that you mentioned, but I totally agree with your point about proper gain staging. Gain and power staging are key in amplifier design.When you say "readily available" I have to raise a small flag. If readily available means that there are a lot of 'em on e-bay, then that's a "qualified" readily available. The buyer must be ready for a certain amount of trial and error before they receive what they thought they were buying. That's just my experience anyway.Also, I'm not not sure if 300Bs are the most expensive power tubes. For example, new in box matched JJ's 2A3s and 300Bs cost about the same. I don't really see a bargain when it comes to choosing a power triode.
Do people consider using expensive tubes that are even more expensive to design & build around a reasonable thing to do, on average? Saying something is expensive is a relative term, I realize that- but not when looking at the ratio of wattage to dollars to performance.
But hi-fi isn't about good economics, its about getting the best sound at all costs. Purist SET lovers, rarely are willing to accept IDHT, strapped pentodes or parrallel output tubes as a solution, considering all of those solutions as an inferior design. People spend so much money on this hobby. Just look at the number of >$1,000 power cords, and then consider that $300/pr for new production 300B tubes isn't that big of a deal. KR, EML and new production WE 300Bs at $700-1000/pr seem to sell very well.
I see your point, but their assumption that expensive triodes are the only conveyance for high quality sound is 100% wrong. They do possess a specific flavor of sound, but I would never, ever call it superior. It is simply different. I like the richness of 813's (pentodes) & 845's myself!
845s at high power operating points are very hard to drive due the need for lots of gain at low distortion and ability to deliver some current at the same time to avoid slewing (rolling off of highs). This is not an easy task and designers spend a lot of time coming up with clever ways to do it. Single stage 12AX7/6SL7 drivers need not apply.
