10B Pro Sub Connections
0 Members and 1 Guest are viewing this topic. Read 1038 times.
dseipel
« on: 6 Apr 2010, 07:58 pm »
I could use some help regarding connecting the XLR outputs on the 10B (non-AES pinouts) to mono amps that use the AES pinouts. Does it matter that the hot pin is different?
Also, I am sending the low pass to subwoofers that are RCA input. The manual says to configure the cable with pin 3 hot and pin 1 to ground. Is this correct?
